How do I perform a sharp mx3640 clear error code after a fuser jam?
Sanya
Our print office printer is in loop. The display continues to indicate a maintenance warning following the clearance of a paper jam in fuser unit. I have rebooted it, switched it on and off, but the message is not removed. I recall that there is a certain simulation mode or a combination of keys that allows a sharp mx3640 clear error code to be done, however, I cannot recall the actual sequence. I believe it is typing the numbers of the keypads in some sequence e.g. press the # key or the C key to access the service menu. Having the step-by-step instructions on how to reset the inner state would be an excellent favor because then we can resume the process of printing our reports.
