How to restart ipad pro?
To restart your iPad Pro, press and hold the Power button and a Volume button (for Face ID models) or just the Power button (for models with a Home button) until the power-off slider appears. Slide to turn it off, wait a few seconds, then press and hold the Power button again until the Apple logo appears.
A restart of iPad Pro requires simultaneous button pressing of the top button and any volume button until you see the power slider. Using the slider, you can switch off the iPad Pro. After a few seconds of initial top button press, you should hold it down a second time until the Apple logo displays itself. A restart sequence begins under Settings > General > Shut Down with an option to activate system power.
  • Press and hold the Top button and either Volume button until you see the slider.
  • Slide to power off, then press and hold the Top button again to turn it back on.
To restart iPad Pro:
  1. Press and hold the Power button and Volume button together.
  2. Slide to power off, then press the Power button again to turn it on.
Here are some steps that help you "How to restart ipad pro"
Press and maintain both volume button and the top button (the electricity button).
Keep protecting until the strength off slider appears on the display screen.
Drag the slider to the right to turn off your iPad Pro.
Wait about 30 seconds for it to completely shut down.
To restart your iPad Pro, follow these quick steps:
  1. Press and hold the Top button and Volume button until the slider appears.
  2. Drag the slider to turn off.
  3. Wait, then hold the Top button to restart.
